Login Error
Close
Create a Hand-Painted Bathroom Vanity
by DoItYourself Staff
Adding an affordable custom touch to any bathroom is easy with a hand painted bathroom vanity. Here are a few paint options and effects to consider.
Glaze
Glazing is a charming effect that can be done on any wood surface. Apply white shellac over the painted surface, and then rub in a small amount of a contrasting color. You will need to use the paint generously, and then wipe it off with rags. You will go through a lot of rags with this project, but it will look fantastic!
Stippling
A slightly different method from the glaze is stippling. Stippling is achieved by using the same method as glazing, only you will use a long brush instead of the rags. Stippling is generally used if you want a slightly more elegant look.
Crackle
Crackle is one of the easiest finishes to use on wood. The result will be a great antiqued look to anything you apply it to. This is a popular customization for those who have a country themed home. Crackle is applied in several steps. You can purchase the medium to achieve this at any craft store.
Stencils or Freehand
If you are looking for a more customized look, you may want to consider using stencils or freehand paint techniques. The advantage of this is that you can gain a completely customized look to match any décor. You will need to spend time and have a lot of patience to do this.
 forum activity
