Creating the Right Soil Mix for Square Foot Gardening
what you'll need
- Peat moss
- Coarse vermiculite
- Compost
- Large Tarp
- Wheelbarrow
- Pitchfork
- Shovel
- Water
- Raised garden boxes
- Seeds and starts
Square foot gardening is a particular method for growing plants and vegetables in raised beds that uses a mixture of planting material that are lighter than dirt. Soil and even soil mixed with compost can be quite heavy, full of clay or slow draining. Square foot gardening uses a light growing material that allows seeds to easily push through the mix. The roots have room to expand, and because there is no dirt there are no weed seeds. Creating the right mix of soil is a simple matter of knowing the proportions, measuring the volume of your growing area, and mixing the ingredients.
Step 1: Measure Your Growing Area Volume
Volume of a space is equal to width x length x height. For a raised garden box with dimensions of 4 by 4 feet and 1 foot deep, that equals 16 cubic feet of volume. Calculate the volume for each of your raised boxes and then add the volumes together to get total volume.
Step 2: Purchase the Ingredients
The lighter-than-dirt mixture used for square foot gardening is the following: 1/3 peat moss, 1/3 vermiculite and 1/3 compost. For a 3.5 cubic foot bag of vermiculite, on average you will spend $18. A 3.8 cubic foot compressed amount of peat moss is roughly $9. You should acquire different types of compost. You can usually find several different mixtures of compost in bulk for around $30 a truckload. You can also buy it pre-bagged. A 1 cubic foot bag usually costs around $2.
Step 3: Mix the Ingredients
If you only have one raised box to work with, you can probably mix the ingredients in several batches in a wheelbarrow. Otherwise, lay out a large tarp and put down the measure of compost followed by the peat moss and vermiculite. For example, if you have three 4x4 beds that are each 1 foot deep, you will need 48 cubic feet of mix. That equals 16 cubic feet of each of the ingredients. According to the above measures, you will need approximately 5 bags of vermiculite, 5 measures of peat moss, and 16 bags or one truckload of compost.
Once on the tarp, mix thoroughly with a pitchfork or shovel. You want the ingredients well blended before you shovel them into the garden boxes.
Step 4: Fill the Boxes
Once mixed, each box should get roughly the same amount of the blend. Now you can begin to plan out what will be planted where. You can use both seeds and starts to plant your garden. The light mixture allows the seeds to germinate easily and the roots to expand. Another great aspect of this mixture is that it is almost impossible to over water. The mix is so light and well draining that the water never pools up.
Square foot gardening is the method of choice for flower and vegetable gardeners who want a lighter, more flexible way to grow their plants. Calculating the mix is a matter of knowing the proportions of 1/3 peat moss, 1/3 vermiculite and 1/3 compost, determining the volume of your growing area and purchasing the right amounts of each.
