Cutting a Crown Molding Inside Corner: Mistakes to Avoid
If you need to cut a crown molding inside corner, you should try to avoid committing any of the commonly made mistakes described here.
Not Using the Right Equipment and Tools
In order to cut corners for crown molding, you need to use suitable tools and equipment. Emphasis needs to be placed especially on the angle. Hence, if you do not use a miter saw or a circular saw, you will most likely end up with an incorrect angle and an improper corner. A protractor may also come in handy.
Not Adjusting it at the Correct Angle
If you do not place the molding on the saw table in a suitable position, and if you fail to set the cutting adjustment at the correct angle, the cut will be imprecise.
Failure to Make Guidelines or Markings
If you refrain from outlining markings on the back part of the molding, you will most likely end up with an incorrect angle. A marking traced on the back of the molding will greatly help you during the cutting phase, and it will improve the likelihood of achieving a correct angle.
Failure to Check Out the Corner Molding with the Walls' Corner
If you skip the checking part, you may have an inaccurate fit. You should always place the corner molding against the corner on the walls so as to see whether it fits in well. This will also help you to make any necessary trimming with a metal file.
