Damp Basement Proofing Using Household Objects
what you'll need
- Shovel
- Rocks and Gravel
- Thin Socks
- Coal
- Sealant
- Plastic Pipes
- Bucket or Pan
- Box Fan
- Rock Salt
You can do damp basement proofing without spending too much money on costly waterproofing materials. During rainy or wet seasons, the basement gets too humid, making it wet and harder to clean. Furthermore, the humidity also promotes the growth of molds and mildew. Follow the steps below to minimize these problems and have a basement free from excessive moisture.
Step 1 – Fix All Leaks
Before you begin, make sure that the basement is free from pipe leaks that can lead to more moisture. Use a sealant such as epoxy to seal the areas where water is leaking. It is a wise decision to strike the source of the problem.
Step 2 – Clean the Basement
Damp basement proofing starts with a clean basement. Remove everything on the basement that may impede the task. Clean debris that can be found lying on the floor. Use a broom and a brush to sweep the floors clean. A clean basement will also reveal problem areas such as cracked walls and holes which can be repaired using cement.
Step 2 - Use Rocks and Gravel
Gravel and rocks can help absorb moisture in the basement. Use a shovel and a bucket to collect gravel and rocks. Spread the gravel evenly on the basement floor or only on the corners and peripherals. During rainy seasons, water usually seeps into the basement walls. The gravel and rocks covering the sides of the walls will help absorb the moisture and prevent it from spreading throughout the basement.
Step 3 – Hang Thin Socks with Coal
Coal has moisture absorbing property as well as an odor absorbing property. Damp basements usually have an unpleasant smell due to the growth of molds and mildew. In order to keep the basement dry and odor-free, place pieces of coal in some used socks and hang them on the basement. They can be hanged on the walls, on the ceiling or anywhere convenient. For larger basements, hang more socks with coal. The coal should get help get rid of the excess moisture in the room.
Step 4 – Use Rock Salt
For very humid basements, the use of rock salt is an effective way to reduce moisture. Rock salt has a very strong dehumidifying effect. It is also an inexpensive way to dehumidify the basement and is a very common substance that can be bought anywhere.
To effectively lower the humidity on the basement, fill a 6 gallon bucket with rock salt just a bit more than halfway. Place the fan over the bucket and turn it on. This allows the air to circulate over the substance. The process may take a few hours. When the salt is saturated with water, dry it under the sun. Repeat the process until the moisture on the room is back to normal.
