Dangers of Growing Russian Sage
Russian sage is a beautiful perennial with small blue flowers that is neither Russian, nor sage. Though it has the aroma of sage when the leaves are crushed, the plant is inedible and actually can be quite poisonous. The following is a guide to the dangers of growing russian sage.
Dangers of Russian Sage
Because this plant is not related to the edible sage varieties, it should not be used in cooking or eaten in any matter because of its poisonous leaves. The effect on each person can vary greatly depending on your body’s individual reaction, but generally it is not considered toxic. Additionally, handling the plant has been known to cause skin irritation or an allergic reaction in some individuals. For this reason, you should always wear gloves when working with Russian sage.
What is Russian Sage?
Russian sage, or Perovskia Atriplicifolia, is a late summer blooming plant that has gray-green leaves and silverfish-gray stems that creates a burst of vibrant color in a garden at the end of the summer. Its tiny purple-blue flowers cover the plant’s long stems with elegant tubular flowers. Bearing a resemblance to lavender, Russian sage grows predictably in areas that are too cold to grow lavender. As a member of the mint family, Russian sage will grow hardy throughout zones 4-9.
Russian sage is native to Central Asian countries such as Afghanistan, Pakistan and Tibet where it can grow at elevations up to 8,000 feet. The plant has been in cultivation in this area since at least the mid-1800s.
Where to Use Russian Sage
Russian sage works well in the middle or back border of a garden or landscape. It looks great when paired with ornamental grasses as well as white or yellow flowering perennials. There are many plants that make good compliments too Russian sage including white phlox, blackeyed Susan and coreopsis. Dark green foliage also makes a great contrast and blends nicely with other silver-leafed plants.
The silver color of the plant’s leaves and its open and airy growth give a landscape a Mediterranean feel. Particularly effective as a filler plant, Russian sage can also be used to separate areas of strong color in a garden.
Russian sage should be grown in the full sun in well-drained soil. Plants should be spaced about 18 inches from one another. They should be watered well throughout the plant’s first growing season to ensure that they establish an extensive root system. However, once established, they are very tolerant of droughts.
Russian sage is quite easy to grow once it becomes established. To prevent flopping while young, the plant can be staked or planted in close proximity to other plants that will support it. Russian sage must be planted in soil with good drainage and aeration, as the plant’s roots will rot if the soil is too wet. Prune stems to about one foot in the spring to avoid the plants becoming too woody and fertilize before new growth in the spring.
