Login Error
Close
Dangers of Turbo Nozzle Pressure Washer
by DoItYourself Staff
A turbo nozzle pressure washer can be a great tool to have around the home and workshop but it can also be dangerous if handled improperly.
How it Works
Turbo pressure washers have the capability to remove paint, stain, mold, mildew, grease and grime from most hard surfaces around your home. It is a powerful tool that emits a steady stream of water that is boosted in strength by being forced through the machine with pressure.
Be Safe
Because of the incredible power of a pressure washer you may be tempted to miss use it. Although some people wash their cars with one on a low pressure setting, always do this with caution. extreme pressure could damage your paint and even break glass.
NEVER aim a pressure washer at a person or pet. On a high setting skin can actually be ripped open and they could suffer severe injuries.
Proper Settings
If you wish to wash your house or windows with a pressure washer do not use a high setting. You can actually rip siding from the house and break glass with a turbo setting on a pressure washer.
If cement is loose or slightly damaged, be careful pressure washing it because it also can be lifted and destroyed if the setting is too high.
 forum activity
