Login Error
Close
Dangers of Using Discount Auto Body Paint Repair Supplies
by DoItYourself Staff
It is possible to find good discount auto body paint repair supplies. However, many repair kits cut many angles and corners in order to make a profit. If you are not aware of the dangers in common discount repair kits you could end up making damage on your car much worse.
Ingredients or Materials
The ingredients and materials in discount auto body repair supplies will not be as good as those in more expensive versions. The reason the price for a discount kit will be so low is because the materials and ingredients do not cost as much. These low cost alternatives may react with the paint on your car and make a small flaked area even worse. This will mean you have to spend even more hiding the larger problems, which will be created.
Tools
Be very careful when you use any discounted tools in auto body paint repair supply kits. These tools will not be as refined as the tools in expensive and professional repair kits. If you jump in at the deep end and use discounted tools you could make a dent in your car bigger or a scratch even longer. This will mean more money getting the damage professionally repaired at a garage.
 forum activity
