Login Error
Close
Decorating a Bathroom Vintage Style
by DoItYourself Staff
Vintage bathroom decorating transforms a plain space into a charming, comfortable sanctuary. Take an authentic approach to vintage bathroom decorating by scourging salvage yards or auctions for tubs and sinks. If you already own a vintage tub or sink, you can refurbish them.
What Is Vintage Style?
Vintage bathroom decorating incorporates design elements from the early 1900s. Vintage style brings forth a time in home building when craftsmanship and function prevailed. Tubs and sinks are the centerpieces of vintage bathroom decorating. Completing the design are frosted globed or shaded sconce lighting and white molding. Keep in mind a clean bright space with a touch of elegance, when decorating your bathroom in the vintage style.
The Color of Vintage Bathroom Decorating
In vintage bathroom decorating, white is the dominate color for the walls, tiles and fixtures. Black is used as an accent color. Walls are white or half white with a color on top. Tiles and countertops are white. Add black in the floor tile or as a wall tile trim color.
Vintage Tubs
Three styles of vintage tubs exist in vintage bathroom decorating the claw foot, slipper and pedestal tub. The claw foot tub is raised off of the floor on legs with claw shaped feet. The slipper tub is sloped higher on one or both ends of the tub, so you can lean against the side while taking a bath. The faucet is usually positioned in the center of the tub. A pedestal tub sits on a skirted bottom.
Vintage Sinks
The most common sinks found in vintage bathroom decorating are the pedestal and console. Sinks mounted in a vanity with marble countertops are also found in vintage decorating. The pedestal sink is mounted on a single base while a console sink sits on two or four legs. The console sink with two legs is anchored to the wall.
Vintage Bathroom Walls
White subway tile is a classic choice for vintage bathroom decorating. Other materials found on the walls of a vintage decorated bathroom are beadboard or paneled wainscoting. Construct the tile or wainscoting half way up the wall and top it with a small shelf or black tile.
Vintage Bathroom Floors
Small white hexagonal tiles applied to bathroom floors provide a vintage look. Black and white tiles infuse the room with vintage detail. Using larger square tiles set on a diagonal gives your room an updated vintage appearance.
Vintage Faucets
Vintage bathroom faucets have a graceful curve with cross handles. Faucet finishes in vintage bathroom decorating are nickel, brass or copper. The faucet handles also come in enamel labeled hot or cold.
Vintage Mirrors
Covering an entire wall with a mirror trimmed in white molding is a modern approach to vintage bathroom decorating. A recessed medicine cabinet with a mirrored front over the sink lends a genuine aspect to the vintage bathroom.
 forum activity
