Login Error
Close
Decorating Patio Sunrooms with Curtains
by DoItYourself Staff
what you'll need
  • Fabric hooks
  • Measuring tape
  • Pencil
  • Paper
Patio sunrooms are typically attached to the exterior wall of a house. They have a great deal of window space to allow the sun into the room. Decorating the windows can require some special planning. You will want window coverings that will accent the room and allow as much light as possible into the space. The window coverings you install should work well with the overall décor of your home.
Step 1 – Determining the Amount of Sun
Carefully watch the light as it comes into the room throughout the day. Determine when the light of the sun is brightest in your room. This light could potentially fade the fabric in the room so you will need curtains that will block the rays to prevent any sun damage to your room. Be sure you choose a curtain that is resistant to sun to protect it from the light as well.
Step 2 – Measuring Your Windows
Decide whether you want your curtains to cover only the window space or to cover the space from the ceiling to the floor. Use a tape measuring tape to determine the length of curtains you will need. Write your measurements down on paper.
Step 3 – Choosing Custom Curtains
Decide whether you would like customized curtains or prefabricated curtains. Customized window coverings work best with windows that have an irregular shape or size. They are more expensive than prefabricated curtains. Be sure to choose a reputable drapery service to make your curtains. Check to be sure the customized curtains come with a warranty.
Step 4 – Choosing Your Fabrics
Determine which type of fabric you want to use. There are a variety of window covering fabrics available. Visit your local home improvement and fabric store and speak with a professional about your sunroom curtain plans. Choose the color and design of the fabric as well.
Step 5 – Choosing the Hanging System
Decide which type of hanging system you want for your windows. Some systems are installed inside the window frame while others require a rod that is hung above the window. A variety of curtain rod sizes, shapes, colors, designs and materials are available.
Step 6 – Choosing Prefabricated Curtains
Standard sized windows can be covered with prefabricated curtains. These curtains are available in many different colors, sizes and designs. Be sure to check that your prefabricated curtains can be returned if you find that they do not suit your room.
Step 7 – Adding Blinds
Consider adding blinds to your curtain décor. There are many different types of blinds available including bamboo and film. You can choose the size, style and color you need to work with your curtain choice. This addition to your window covering system can help to block out excess glare and provide extra privacy to your sunroom space. They are typically easy to install and simple to use.
 forum activity
