Login Error
Close
Decorating with Architectural Corbels
by DoItYourself Staff
what you'll need
  • Corbels
  • Level
Architectural corbels can either be decorative or structural depending on why you want to put one in your home. Corbels add a touch of class to any home when used for decorating. Here is how you can use architectural corbels to
Step 1 - Decorate Your Kitchen
Corbels can be use in the kitchen to appear to be supporting brackets under the kitchen counter. Make sure to get a color that matches your counter so it can blend in.
Step 2 - Decorate Your Living Room
Larger corbels can be mounted on the walls to be used as hanging shelves. Make sure you that if you use the corbels as a supporting piece, that is can actually hold up whatever you put on top of your hanging shelf.
Step 3 - Decorate Your Bedroom
Much larger corbels can be used as night stands place on both sides of the bed. Here you can place a small lamp or perhaps the telephone.
Step 4 - Decorate Your Hallway
Corbels are usually placed on archway corners to soften sharp edges of a hallways frame. Get or paint a corbel that is the same color as the doorway arch so it can blend in and won’t stand out.
Step 5 - Decorate Your Library
Smaller corbels can be used as book support in your library. Be creative and get a variety of colors use them to hold your books up on shelves.
 forum activity
