Login Error
Close
Denatured Alcohol vs. Linseed Oil
by DoItYourself Staff
Denatured alcohol and linseed oil both have several different types of uses, but are both very different when compared to the other. You will find that knowing the difference between the two is important so that you will know what you can use each for. Knowing why you would want to use each one will help you to get the most out of both linseed oil as well as denatured alcohol.
Denatured Alcohol
Denatured alcohol is used for several different common every day uses. For instance, it can be used as fuel when camping, such as for backpacking stoves. You will be able to purchase denatured alcohol cheaply and can easily extinguish it with water. Something else to know is that you will not have to worry about using any type of special containers whenever you are transporting it. However, there is a near colorless flame that goes along when alcohol burns. This is a danger that should be noted. You will also be able to use denatured alcohol as an exterminator for mealy bugs. It can remove ink stains from cloths or upholstery. It is an excellent cold sore treatment. One of the main reasons that denatured alcohol is still being used is because it is a much cheaper alternative to pure ethanol.
Linseed Oil
Linseed oil also has several different everyday common uses that it can be used for. Typically, you will find linseed oil to come in a liquid. Linseed oil is often is used in oil paint. It helps to give oil paint the fluid and glossy appearance that it is known for. As far as the technology of oil painting goes, linseed oil is something that has helped it to come a long way. Glazing putty is something else that can benefit from linseed oil. It is typically used as a type of a sealant for the glass windows.
In a few weeks time, it will completely harden and can be painted over. Wood finishes that are treated with linseed oil will appear to look much shinier surface that will help to show off the beauty of the wood. It also protects the wood from scratches and dents. Linseed oil can also be used to help protect instruments such as the mandolin and the guitar. It can help to protect against the skin oils and the moisture that can deteriorate the wood overtime.
Which is Best
Basically, what it all comes down to is the way that they are most typically used. You will find that with linseed oil, it is used best whenever you are using it to protect surfaces. It is also great for making things appear shiny and new, still while strengthening and protecting them. Denatured alcohol is something that can be used for several different types of things, as an exterminator, stain remover and to provide heat as well. Denatured alcohol is something that can be used to heal the skin and remove fungus. While denatured alcohol is something that has a broader category of things it can do, linseed oil can be used more often.
 forum activity
