Login Error
Close
Design Ideas for Cable Stair Railings
by DoItYourself Staff
Cable stair railings are becoming more and more popular with the attractive qualities it brings to your staircase. It is modern, sharp, and eye catching all at the same time. There are so many different ways you can bring cable stair railings into your home. They are a nice addition to any home, with any type of decor. They can be applied to wooden frames as well as metal frames.
Because of their clean and understated lines they fit in nicely with any type of stairs. Below you can discover a few different design ideas when you are seeking out the look of cable stair railings.
Overlooking a View
This is one of the most common ways that cable stair railings are used. This type of design is not actually used as any type of hand railing. You will often see this design used as a wall figure overlooking a beautiful view of some sort.
It usually is installed off a patio on a higher floor. Imagine walking out your patio door, onto a cement slab, and being able to walk over to a beautifully designed cable railing, and then looking out onto some beautiful scenery.
End of Staircases
Change of direction stairs are very common. These are stairs that will bring you up one flight with a slight landing, and then up to another set of stairs. Cable stair railings are often seen at the end of those landings. Because of the cable, it does not put up a blockage of any sorts. You can see right through to the other set of stairs. It's often used for decor at this point and not a railing of sorts.
Spiral Staircases
Because spiral staircases are often built of stainless steel, and even wrought iron, cable stair railings fit right in this type of stair design. Cable stair railings can bend, twist, turn, and even go opposite directions. So using this type of railing on a spiral staircase is a great idea.
Mix and Match
Cable stair railings are very versatile. They can blend in with any type of stairs. If you apply cable stair railings to a wood staircase it adds elegance and modernism to a natural feel inside your home.
Use them in conjunction with wood posts at the end of the railings as well. This gives it a clean, fresh, crisp line, and then an elegant detailed wood at the bottom.
Opposite Directions
This is a favorite among many. Again, because of the unobstructed view cable stair railings give, using them in a long flight of stairs that have an up and over feel, you can use them together, and create a long lengthy flight of stairs. This gives you the chance to see the top floor as you are walking up to it.
You will see this done in places like hotels, and office buildings. However, with the clean lines once again, using them in your home gives it a very modern look.
 forum activity
