Login Error
Close
Design Ideas for Custom Wood Screen Doors
by DoItYourself Staff
Wood screen doors are one of the most important fixtures in your home. It serves many purposes, the most notable being to keep the wind from pounding at your front door and bugs from flying inside. Your house can reflect not just a great interior design, but you can have an equally appealing exterior design.
When you are having a custom screen door made, there are several different designs that you can choose from. However, note that some manufacturers will actually allow you to draw up your own design, which will help match the door to the design and style of your house.
If you use a wood screen door which is less than 1 inch in thickness, you will have a basic design with no glass installed. The thicker the wood of your screen door, the more durable it is and will hold up to inclement weather. Also, if you have a thicker door, you have the option of adding glass panels which will gives more options with designing the door you want.
Traditional Doors
Most customers choose a standard square frame. This is known as a traditional screen door and will not cost you quite as much. If you are looking for a more specific, intricate design, a little more effort and cost is expected.
Craftsman Style
If you want something that looks bold, then you would be interested in the craftsman design. These screen doors come with removable fiberglass screen inserts which you can paint and stain with your own design. These designs have a historical significance and celebrate a style and workmanship when craftsman and artists brought creativity to every object they produced. It gives your entrance a truly hand-crafted look.
Victorian Finish
While it won't hold up to a heavy storm, a Victorian style door is a great choice. These are normally great designs reminiscent of the Victorian era. Some of the designs are more fragile than others, so be careful with them while both installing and using. They may also require more maintenance.
Pet Passage Doors
Many Craftsman and Victorian style doors are enhanced with a pet passage door at the bottom which allows easy access for your animals to come and go as they need do. Traditionally plastic flaps have been used, but when custom making your wood screen doors, you can add a wooded flap that blends into the design of the door.
Double Doors
For a truly rare and unique look, you can choose to have double screen doors made for you to match your main double doors. This is especially doable if you have doors that open into the room, then the screen doors will swing outward. These doors can be painted with any design to add a little elegance to your front entrance, or can be left plain to leave a more traditional look.
Unique Design
If you are an experienced woodworker, then you could create the wooden screen door by yourself and choose any design you want. This will take considerably more time, but you have to take into account that you are getting the screen door of your choice and it will truly reflect your personality. Craftsman, Victorian, Double, there are many choices, and it is important for you to choose one that fits the style of your home.
 forum activity
