Login Error
Close
Design the Perfect Bathroom Vanity Sink
by DoItYourself Staff
There are a wide variety of different considerations to make when it comes to renovating and remodeling your bathroom, and one such consideration to make is how to design a bathroom vanity sink. Here are some tips to designing the perfect bathroom vanity sink.
Step #1: Figure Out Your Needs
There are a number of important things that you are going to need to bear in mind when it comes to designing or purchasing a bathroom vanity sink. For example, the widths that you will find from one bathroom vanity sink to the next are going to vary significantly between a nice 18 inches to a hefty 48 inches in width.
Typically you will find that the increments for bathroom vanity sink options climb by 6 inches at a time. You also need to consider the materials as most bathroom vanity sink options are made from wood and other man made materials such as cherry wood, oak and walnut. What material you end up choosing is going to depend heavily on what look you are going for when it comes to your bathroom.
Step #2: Check Out the Types of Vanities
There are four different primary types of bathroom vanities and vanity cabinets that you are going to want to put consideration into when it comes to finding the perfect bathroom vanity sink. The first option is the simplest as well as the easiest for you to install, which is to use a simple cabinet that is capable of being mounted directly on your wall. Another type of bathroom vanity sink for you to consider is the shelving option. You can try installing recessed shelving in either the corner or along a flat wall.
The third type of bathroom vanity sink for you to consider is something that fits directly over the toilet. There are a wide variety of different options for this type of bathroom vanity sink depending on what your needs are. Finally, the fourth and potentially most popular type of bathroom vanity sink is cabinets that fit directly beneath your sink. There are freestanding types of cabinets that you can choose from and there are also built in cabinets that you can choose from depending on what your needs are.
Step #3: Check Out the Styles of Vanities
Finally, there are two different styles to consider when it comes to choosing a bathroom vanity sink. The first type of bathroom vanity sink is a face frame cabinet and the second is a frameless bathroom vanity sink. The face-frame version is more formal and traditional in nature with hidden hinges. The other option is frameless with a much more modern look in appearance. Any time that you want to improve the way your bathroom looks, make sure to consider your options for finding the perfect bathroom vanity sink.
 forum activity
