Login Error
Close
Designs and Patterns for Brick Patios
by DoItYourself Staff
Choosing the right design for brick patios can seem like a daunting task. After all, there are so many options from which to make your selection. This article will help narrow your choices by exploring the five most common types of designs used for bricks patios. So if you're in the market for a new patio design, read on.
Stretcher Bond
The stretcher bond is the most common type of design used for larger bricks patios. Aesthetically, the stretcher bond is very simple--it is composed of red and browns stacked together in a side-by-side fashion. Despite its simplicity, this design looks good on virtually any patio and does a good job complimenting the exterior of most homes. As a possible downside, many artistically-inclined homeowners find the stretcher bond to be somewhat bland and uninspired.
Running Bond
The running bond, much like the stretcher bond, is made up of red and brown bricks that are arranged in rows in a side-by-side fashion. The bricks that make up the running bond are relatively smaller and not as wide as those found in the stretcher bond. The seams found between the running bond's bricks serve as its key aesthetic trait, helping to distinguish it from the stack and stretcher bonds.
Stack Bond
The stack bond, which is composed of red bricks stacked together in an up-and-down fashion, is another popular design used for brick patios. The stack bond's primary distinguishing characteristic is its perfectly even seams, setting it apart from its similar-looking counterpart the running bond. Like the running and stretcher bonds, the stack bond gives patios a simplistic and dignified look and meshes nicely with the exterior of almost any home.
Parquel
The parquel, also commonly known as "the basket weave," is a design that is used almost exclusively for brick patios found outside of older homes. The parquel originated in seventeenth century Europe and is composed of bricks that bear a strong resemblance to baskets being woven. Although this design looks good with older homes, it does a poor job of meshing with houses that were constructed in the last half century. Additionally, the parquel's installation process can prove somewhat difficult--especially when compared to the relatively hassle-free installation processes associated with its modern day counterparts.
Random Mix
If you're a creative-minded homeowner who's looking to give your patio a hip, cutting edge feel, look no further than the random mix. As the name implies, this particular design is composed of an assortment of differently shaped and colored bricks. The random mix is a fairly new patio design, but it is quickly garnering a great deal of popularity with the more artistically-inclined among us. Although the random mix goes well with most newer homes, people with older houses would probably be better off with the parquel or the running bond.
Now that you've read up your options, you should be well on your way to choosing the right patio design for your home. With this handy guide at your disposal, you're sure to find that selecting a patio design can be both fun and rewarding.
 forum activity
