Different Bathroom Fan Light Types
A bathroom fan light is one of the necessary components of a healthy bathroom. These fans remove unpleasant smells as well as excessive moisture from the room. When shopping for a bathroom extractor fan, you can choose a functional or decorative model that mounts to the ceiling or to a window.
Ceiling Bathroom Extractor Fan
The most common type of fan used in a bathroom is a ceiling-mounted extractor fan. These fans come in several varieties including fan/vent combinations, fan/light combinations and fan/heat lamp combinations. The option that you select will depend on your budget and your aesthetic desires.
If you do not want to spend much money or you are renovating a seldom-used or guest bathroom, your best bet is to select the fan/vent option. If you have a larger budget to work with, go with a designer fan/light style.
Decorative Bathroom Extractor Fans
If you want to get rid of your window fan when you upgrade your bathroom, consider selecting a decorative bathroom extractor fan. These fans come with lights in many designs, colors and shapes. For example, there are frosted glass dome lights, Tiffany-style lights and modern-industrial light designs.
You might also select a decorative bathroom extractor fan based on its frame color or style. Frames come in wood grains and metal and glazed finishes.
