Login Error
Close
Different Kinds of Bathroom Fixtures for Disabled People
by DoItYourself Staff
Gone are the days of primitive and bulky handicapped fixtures for the bathroom. Innovative help for the disabled abounds from simple needs for independent support to full time assisted living care aids.
Bath Tub Fixtures
To provide minimal support there are easily installed and removable trellis type handles which are attached directily to the bathtub for safer leg lifting and body lowering into the tub. This simple non slip design attaches easily and securely to the side of the tub.
If a person is beyond being able to lower themselves into the tub there are two options. The first is a waterproof chair designed to be used in the bath that is the same approximate height of a dining room table chair. Many are equipped with a flexible shower nozzle holder and accessory baskets to keep both the water source and bathing products within easy reach.
Some of these chairs actually extend beyond the tub and straddle over the rim of the tub. This enables the user to sit first on the edge of the chair and swing themselves into the tub without having to stand and lift legs over the side.
The most elaborate designs include entry doors that open and then close with a water tight seal to create a sitting bath type experience without having to maneuver over the edge of the tub. The existing lower tub design will be removed and the door tub will be fitted into the space.
Several options are available with this door type tub which include air or water jets, tiled enclosures, temperature controls and automatic water sensors.
Shower Fixtures
These provide 3 sided enclosure with hand rails of various sizes and heights on all 3 sides. The floor lip of the shower stall is minimal for ease of wheelchair access. If no wheel chair is involved, a built in bench can be included.
A shower head with an adjustable rope type sprayer makes for ease of showering.
Toilet Fixtures
If you have not yet installed a toilet for a disabled user, toilet designs options are available. Some include handles, others an extended bowl, but most provide attachments that provide ease of use. Most accessories revolve around the seat itself.
A person can find extensive lift systems that act as a lift chair so there is no back or leg stress on the user. They are also equipped with simple push button controls for users to maintain a degree of independence and privacy.
Another option is a bidet type seat that is also hand controlled. This bidet seat provides an adjustable, oscillating spray, controllable water pressure and continuous warm water. It does not include a lift system.
For all systems automatic flush sensors can be attached.
Vanity and Sink Fixtures
Depending upon the disability, sinks should be placed lower, extended closer to the counter outside edge and built without a cabinet to keep the underside open for wheelchair access.
Automatic senors on the faucet will alleviate any need for manual manipulation of having to turn the water off and on. There is also the automatic air dryer option and auto soap dispenser available for complete and uncomplicated hand hygiene.
 forum activity
