Different Types Of Thermostats Explained
A thermostat is important in ensuring that the heating system installed in your house works optimally. This gadget can set set to turn your heat on or off, and to what temperature the heat will rise or fall. When used responsibly a thermostat can be your partner in managing your power bills. When shopping for a thermostat of any design it is advisable to select one with an ENERGY STAR symbol.
Thermostats are available in two basic thermostat types
1. Line-voltage thermostats
These thermostats are used in single heating systems including radiant systems and baseboards. Line voltage thermostats are installed in series with heaters, mostly at 240V. In this type of connection the current flows through the thermostat and into the heater. Unfortunately, it is possible for the thermostat itself to reach the set room temperature, causing it to shut off even before the heater has brought the room to the set temperature.
2. Low-voltage thermostats
Low-voltage thermostats are more efficient when it comes to the controlling of current flow. These thermostats are used in central heating systems that use electricity, gas and oil. They are also used in water heating systems particularly in zone valves, and in electric unitary systems. With a low-voltage thermostat you will not only be able to accurately control current but you will also have an easier time using programmable controls. This ease is mostly due to the fact that they operate at 24V to 50V as opposed to the 240V used for line-voltage thermostats.
Line-voltage and low-voltage thermostat options:
Programmable thermostats. With a programmable thermostat you can have the temperature in your house automatically adjusted according to preset times. This means that you will have an easier time conserving energy since you can let the gadget reduce the temperature in your hours of absence and increase the heat when you are around.
Programmable thermostats can be purchased in several models. The simpler ones allow you to program daytime and nighttime temperature settings while the more complicated ones can be programmed to adjust temperature differently for different days and times of the week.
Mechanical thermostats. These are perhaps the cheapest and easiest thermostats that you can install. They feature either vapor-filled bellows or bi-metallic strips, which respond to variations in temperature. Mechanical thermostats are often considered unreliable, particularly the cheapest models that make use of bi-metallic strips.The major letdown you will experience with these thermostats has to do with slow response of the bi-metallic strip, which may result in significant temperature variations either above or below the desired set points.
Electronic thermostats
Unlike mechanical thermostats, these thermostats make use of electronic gadgets to detect temperatures and subsequently initiate control for your heating system. They are quicker in responding to temperature variations.
You can have electronic thermostats either for line-voltage or for low-voltage purposes. These gadgets will offer you much convenience with features like programmability and automatic setback. For these reasons, electronic thermostats will cost you more than the mechanical alternatives.
