cancel
Job type :
Zip Code :
community forums
comments
Direct Vent Fireplace Installation Tips
With a direct vent fireplace insert there can be a few safety concerns that need to be taken into account. These concerns can be minimized with proper installation and maintenance. There are specific procedures and standards that need to be followed with a direct vent fireplace insert to ensure that it operates as safely as possible.
Air Quality Concerns
The main concern with a direct vent fireplace is related to air quality. These fireplaces vent directly into the room. They take oxygen out of the room and replace it with carbon monoxide. If there is not enough oxygen or too much carbon monoxide, there can be a variety of issues that result. There are health concerns and safety concerns with air quality if you do not pay careful attention to your fireplace. Luckily, most of these fireplaces are equipped with a safety monitor and automatic shut off in case of lack of oxygen or over abundance of carbon monoxide.
Installation Concerns
Another concern with a direct vent fireplace is the fact that most often these replace traditional ventilation for a fireplace. If installation is not completed properly, there can be a wide variety of potential problems. Installation should be done by a qualified installer to ensure that things are done properly. This will help keep your family safe and prevent fires or other problems within your home.
member comments
posted Oct 01, 2009
Ah, this article is absolutely not accurate. The author seems to be confusing direct vent fireplaces (which use outside air for combustion) and vent free systems that rely on air from inside the room.
With direct vent systems, both the combustion by products and the fresh air are circulated through a pipe that connects to the outside.
Related Articles
Heating Wood Stoves
Heating wood stoves provide an alternative to fireplaces and other heating options. Similar in design... read more
Chimney FiresChimney Fires
What you should know about chimney fires, how to avoid them, and what to do... read more
Wood Pellet Stoves: Tips and Tricks
Wood pellet stoves are stoves that burn compressed wood for heating residential spaces. Wood pellets... read more
articles we like
Outdoor Chair
An outdoor chair can be a variety of chairs used in outdoor settings which have... read more
Splash Block
A splash block is a small block usually manufactured using concrete which is shaped in... read more
Top Teen Chef's Recipe for Backyard EntertainingTop Teen Chef's Recipe for Backyard Entertaining
Adreena Winnfield knows a little something about cooking. As winner of The Art Institutes... read more
sponsored articles of the day
diy centers
