Login Error
Close
DIY Karaoke Bar
by DoItYourself Staff
When it comes to entertainment for your home recreation room or basement, a karaoke bar is a sure-fire winner for your guests. It’s a great way to entertain men and women of all ages. These karaoke machines require very little setup time and can be incorporated into most existing bars. Just follow these quick steps, and you’ll be singing in no time:
  1. Install soundproofing for the walls in your rec room. You can choose between specially designed acoustical panels or any type of foam insulation panels to do the trick.
  2. Make sure you have the proper accessories like a music stand, a long microphone cord, and maybe an extra microphone for duet capabilities.
  3. Install lighting to enhance your karaoke bar. You can replace a surface lighting fixture with a run of track lighting.  It can work of the same switch and can be installed with minimal work.
No matter what size your recreation room or basement, there is a karaoke bar that will fit your needs. Once you’ve decided on the right design, you can begin to enjoy the endless benefits a karaoke bar can offer.
 forum activity
