Login Error
Close
DIY Rigid Foam Insulation
by DoItYourself Staff
Probably the most attractive advantage rigid foam insulation offers is versatility. This insulation can be used in virtually any area of your home, it is structurally strong, and offers excellent resistance to heat and cold. To understand more about properties of this insulation and why it is so versatile, read the information below.
Molded Expanded Polystyrene (MEPS)
This material is the commonly used to manufacture rigid foam board insulation. This produce can be manufactured in varying degrees of density, depending on its intended application. It is typically used in insulating concrete forms and insulated panels.
Extruded Expanded Polystydrene (XEPS)
XEPS typically costs more than MEPS. Its R-value can vary. It is different from MEPS in that is more dense, its compressive strength is greater than MEPS, and its moisture absorbency is greater. For these reasons it is often preferred for use on wall panels and roofs.
Polyisocyanurate (Polyiso)
This product offers higher R-Values. This allows the contractor or home owner to install a thinner insulation board and yet get the R value of other thicker products. It is also favored as an insulation for roofs.
 forum activity
