Login Error
Close
DIY Water Irrigation
by DoItYourself Staff
If you plan for water irrigation in your outdoor garden, it can create a much healthier garden and save you a great deal of effort. A drip irrigation system can provide simple and money saving irrigation for a small outdoor garden.
Step 1 - Plan Ahead
Locate a water source, such as an outdoor faucet. Use a “Y” connector on the faucet, since the water irrigation system will need to be hooked up all the time. With a “Y” connector, you can always use an auxiliary hose when needed.
Step 2 – Draw Out the Design
You should make a sketch of your garden and indicate each plant. Each plant will need at least one emitter, and some will need two, if they absorb a great deal of water. Hydrangea, rhododendron or tomatoes are examples of plants that need lots of water.
Step 3 – Assemble the Design
Buy the necessary supplies once you have the measurements, and cut the tubes to size. Letting the tubing sit in the sun for a couple of hours will soften it and make it easier to work with.
Step 4 – Hook up the System
Connect the pieces in this order: “Y” connector, an electric timer, a backflow/pressure unit, hose thread adaptor, length of garden hose to reach the garden, hose thread adaptor, drip irrigation line. Adjust the water level, and let it go to work.
 forum activity
