Do brick pavers fade in the sun?
Yes, just like a lot of other things, brick pavers do fade in the sun. However, it is most likely that they will at least all fade evenly, at the same rate, unless you have a section of them at your home that gets more sun than the rest of it. If you are concerned about fading, it might be a good idea to get a light color to begin with, and then the fading wouldn’t be as noticeable, as if you started with a dark color and they lightened up. All in all, there really isn’t much you can do to stop them from fading, since they are outside on your patio directly exposed to all kinds of weather.
