Login Error
Close
Do I Need A Sunroom Building License?
by DoItYourself Staff
When you are in the early stages of planning the addition of a sunroom to your home, start by researching your local zoning laws and building codes to find out if this kind of addition is allowed and what kind of permits and licenses you'll need in order to proceed. Every city has its own building code and making sure that you are in compliance with local requirements is a key element in any successful renovation project.
Building License for Sunroom Additions
If you are hiring a contractor to build a sunroom addition on your home, verify that they have a valid building license to operate in your state. Any reputable contractor should be able to produce their license upon request.
If you are planning on using one of the many do-it-yourself kits to build a sunroom on your house, you will need to check with your local building department to determine if you need a building permit to complete the project yourself.
Before starting any project that involves building or renovating your home check with your local building department to ensure that your plans will fit into your local regulations.
 forum activity
