Login Error
Close
Do It Yourself Roofing Repair: A Guide to Shingles
by DoItYourself Staff
When it comes to do it yourself roofing repair, there is a lot of information that you need to know to be successful. One of the most important parts of roofing is the shingles. There are several types of shingle that you could purchase, and all of them have different features for you to consider. Here are the basics of shingles.
Asphalt Shingles
Asphalt shingles are the most commonly used type of shingles in the industry. These are the most economical choice. Reinforced with fiberglass or paper, in most cases, these shingles can last as long as 20 or 30 years, if installed correctly. Some of the cheaper asphalt shingles on the market only will last about 10 years or less.
Laminated Shingles
These shingles are generally also made out of asphalt but they are made with multiple layers. You will see staggered layers of the material that makes up the shingle. This type of roofing generally lasts 20 to 40 years. They are a good option if you want a nicer look than plain asphalt, but you do not want to spend as much is you would with slate or some other high-end roofing option.
Slate Shingles
Slate shingles are another popular option that many people use on their roof. This is considered to be a high end roofing material. You will find this on nicer houses across the country. The best thing about slate shingles is the longevity. When these are installed correctly, they could last over 100 years without having any issues. Even though the initial cost of this type of material will be higher than other roofing materials, you will not have to worry about replacing it at any point in the future. If you are considering working with slate shingles, you need to make sure that your roof can support the weight. You also need to make sure that you can handle the excess weight of these shingles. Asphalt shingles are heavy enough when you are working by yourself. Slate shingles are very heavy and they can be difficult to install or repair.
Wood Shingles
You might also choose wood shingles. Wood shingles or shakes give you a classic, rustic look on your roof. If you are going to go with this type of material, choose one that is made out of cedar or pine. These are the two best species for this type of application. This type of shingle is generally best for areas in which you do not have a great deal of rain. While it can hold up to some moisture, you want to allow it to dry out occasionally. You can expect about a 30 year lifespan in most situations. You have to be careful with this type of roofing, because of the fire hazard that it presents. Because of that, this material is against the law in some areas.
Spanish Tile
Spanish tile is another product that you can put on the roof. This type of roofing is generally made out of clay and it is considered to be very durable. Some of the products on the market carry with them a 50 year warranty.
 forum activity
