Login Error
Close
Does a curtain room divider cause a lot of damage to walls?
by DoItYourself Staff
If done properly, hanging a room divider curtain causes minimal damage to walls. If you attach one end of the divider to the wall, the only damage you may incur will be some small holes from the screws of the bracket and perhaps some difference in color where the paint has not faded from sun exposure like the rest of the room. Most often, however, the room divider curtain is attached to the ceiling, where there is also little damaged when it is removed. This type of curtain is a perfect solution to divide a space and add color to an rented dwelling where you are not allowed to paint.
 forum activity
