Login Error
Close
Does a Rooftop Deck Add Home Value?
by DoItYourself Staff
From the point of view of a real estate expert, a properly installed rooftop deck adds great value to your home especially if it offers a great view of the skyline or the water. However, if the rooftop deck was installed illegally, that additional feature to your home can be a big problem. To make sure that your rooftop deck increases the value of your home, here are some tips for you.
Follow Building Regulations in Your Area
Before you attempt to construct a rooftop deck on your home, you better check out your local building code. Some areas in the country have very strict rules and regulations when it comes to setting up rooftop decks so if you do not want to end up paying huge fines and penalties for not following the law, you better read your local building code.
Get a Contractor to Install the Deck for You
If you are not a skilled carpenter, you should not attempt to install a rooftop deck on your own. Forget about saving money on professional fees, and instead hire a good contractor for your project. Not only will the contractor save you from all the trouble of figure out what to do with your roof, he can also give you a professional job that can increase the value of your home.
 forum activity
