Login Error
Close
Does Outdoor Wicker Patio Furniture Last?
by DoItYourself Staff
Outdoor wicker patio furniture looks great, but requires special care. Natural unfinished wicker is not meant for outdoor use and will deteriorate quickly on a patio or deck as sunlight and wildly fluctuating moisture from rain and summer heat take their toll on the canes. Coated or finished wicker furniture lasts longer in outdoor settings, since the wicker reeds are coated against the elements. The most durable outdoor wicker patio furniture is synthetic wicker, which still requires extra care for a long life.
Keep Natural Wicker Out of the Elements
Natural wicker is prone to drying out, so it should be kept out of direct sunlight that can sap the moisture out of the canes. Conversely, it can also rot if allowed to remain moist for too long, so it should also be kept out of the rain. As long as it is cleaned regularly with a soft cloth or vacuum, natural wicker can last for years on a covered porch, sunroom or other protected outdoor space, but is better suited for indoor use.
Resin Wicker for Durability
PVC, resin and acrylic wicker give the look of natural outdoor wicker patio furniture with more resistance to the elements, making it a better choice for uncovered patios and decks. While the furniture may be woven on natural cane supports, the wicker mesh is made of a plastic material that doesn't dry out or break. While this preserves the look of wicker for all-weather furniture, resin doesn't feel like natural wicker. High-end resin wicker contains UV coatings to resist fading and damage from prolonged UV exposure.
Cleaning Outdoor Wicker Patio Furniture
Resin wicker should be cleaned periodically to remove dirt and grime that can accumulate in the small spaces in the wicker weave. A strong blast from a hose will clean off most dirt. For body oils, use a multi-purpose spray household cleanser and rinse thoroughly. Try the cleanser on an inconspicuous location like under the seat cushion to ensure that it doesn't damage the finish.
Indoor Storage
Storing the outdoor wicker patio furniture in a garage or shed out of the elements during the winter and early spring will prolong its life. Protect outdoor wicker patio furniture during the warm season by covering it when not in use. Be sure that the furniture is dry before covering, or moisture can promote damaging mold and mildew growth.
Rejuvenate Tired Outdoor Wicker Patio Furniture
Kept clean and protected from the elements, outdoor wicker patio furniture can last for years. Over time, even the most conscientiously cared for furniture will fade from normal use and exposure. If the furniture is in good structural shape, a coat of vinyl dye or paint formulated for plastics can refresh the look of resin or PVC outdoor wicker patio furniture, giving years more service.
 forum activity
