Login Error
Close
Does Replacing Stucco Siding with Brick Improve Insulation?
by DoItYourself Staff
If you replace stucco siding with brick, you can take advantage of a major upgrade to the appearance of the exterior of your house. In addition to that, you can improve the insulation qualities of your home as well. Brick is a much better insulator than stucco and it will significantly improve the insulation. Even though you will be making a large one-time investment when you upgrade to brick, you will generally be able to make up for it over the long-term in the savings from your utility bills.
 forum activity
