Login Error
Close
Doorway Chin-Up Bar Workout Tips
by DoItYourself Staff
Here are some doorway chin-up bar tips that will let you reap all the possible benefits of your doorway chin-up bar.
Warm Up
Before you start working out using the chin-up bar, you will have to warm up your muscles for at least 10 minutes. This will make your muscles flexible and prevent any kind of cramps. Do a couple of stretch exercises to get the muscles used to the pull.
Start Slow
Do not start rigorous doorway chin-up bar workouts on the first day. Start slow so that the muscles of your arms, back and hips gradually get used to the exercise. Heavy exercise right from the beginning can only do more harm than good. Hence, gradually increase the intensity of your workouts as your endurance level increases.
Grasp with Both Hands
You should grasp the handle of the chin-up bar firmly with both your hands. This helps even out the stretch. There is a greater chance that your muscles will get sprained if you do the workout using just one hand. Also, you may fall down and hurt yourself. Hence, until you gain expertise using the doorway chin-up bar workouts, it is strongly recommended that you use both hands to create a good grip.
The Right posture
While exercising using the chin-up bar, having the right posture is mandatory. Make sure that you stand upright without arching your back. Keep your hands straight and firmly grip the bar. Pull yourself up gradually and come down slowly with ease. Avoid jerky movements in order to prevent injury to the back and arms.
Keeping all these points in mind will ensure that you do the doorway chin-up bar exercises carefully.
 forum activity
