Login Error
Close
Dos and Don'ts of Ceiling Paint Color
by DoItYourself Staff
Ceiling paint color enhances the look of a room and provides a good finish as well. When painting the walls with color, the ceiling should also be considered because it also affects the entire mood of the room. When choosing ceiling paint color, there are some things to consider in order not to ruin the interior of the room. Read on for the dos and don’ts of ceiling paint color.
DOS
1. Follow the Color of the Wall
The easiest trick to choosing ceiling paint color is to take a short glance at the wall. The color of the wall should match the color of the ceiling as well. This will make it easier for homeowners to choose which color is appropriate.
2. Pick Colors Yourself
When opting to have the walls and the ceiling painted, make sure to choose the color yourself because the contractor may pick a different color that is not of preference. Always check if the choice of color blends well with the surroundings of the room. Therefore, always be there when the choice of color is being decided upon.
3. Ask for Half the Strength
When opting to use a color that is the same as the wall, choose a paint color that is half in strength as that of the wall color. This will make the ceiling noticeably brighter than the walls.
4. Use White or Light Blue When the Walls are Pale
If the color on the walls are too pale, then asking for paint color that is half its strength may not apply. It is best to choose white color instead. White is also the color of choice for most homeowners. Another choice is to make use of pale blue to imitate the color of the sky.
DON’TS
1. Do not Use Overly Light Colors
When choosing a color that is the same as the walls, never go for a shade of the color that is too light (e.g. ¼ the strength of the wall color). This is not necessary because ½ of the strength of the color is good enough.
2. Do not Choose a Darker Color
As a rule of thumb, the ceiling should not be darker than the color of the walls. Since lighting comes from the ceiling, then the color of the ceiling should be brighter in appearance than that of the surroundings.
3. Do not Use Different Colors for the Ceiling
The color on the ceiling should be uniform in order to create a natural flow. Painting a ceiling in one room with a different color will disturb the flow of color in the interior of the home.
4. Do not Use Colors When the Room is Full of Bright colors
The best color to choose when there are a lot of bright colors all over the room is no color – white. White is best for rooms that are full of brightly colored furniture, upholstery, etc. Painting the ceiling with another color may not blend well.
 forum activity
