Double Window Pane Replacement Tips
If you aren’t an expert in replacing things, than double window pane replacement can pose a problem for you. You don’t need experience building things to be able to do this properly. When replacing double windowpanes, there are a few things you should be aware of. Here are a few tips that can help get you started:
Loosen the Seal Holding with Caution
When loosening the seal holding the frame, use a small knife. This will ensure that you will make a tiny cut in the sealant. Precede with caution.
Removing and Replacing the Seal
When removing the seal from the edges of the frame, peel off any stray fragments. Dispose of these remains properly. Before replacing the seal, make sure the area is clean by wiping it down with a damp towel. Clean off any dirt or debris.
Sealing the Edges with Caulk
With a caulking gun, fill it up with a unit of silicone. You will seal up the frame along its edges. Do this for every frame of the double pane window. Wait a day for the silicone to dry. Waiting for it to dry will prevent any damage from occurring.
