Login Error
Close
Drain Cleaning Services vs Do It Yourself
by DoItYourself Staff
When deciding whether to hire a drain cleaning service or doing it yourself is a task that should not be taken lightly. There are setbacks and advantages with either option. Here are a few:
Money:
The main reason why most people decide to avoid calling a drain cleaning service is the price. Simple drain cleaning can cost hundreds of dollars and just having someone come out to see what's wrong will cost you money. Paying $200 for a professional to clean out the spaghetti noodle from your drain is not desirable and is not money well spent.
Professional Cleaning:
If you are not experienced in cleaning your own drains it is reassuring to have a professional come in and fix the problem. If the drain is really clogged or dirty you can do more damage by trying to fix it yourself with home remedies or cleaning products. Drain cleaning can be very complicated and can require taking apart pipes. It's messy and if you're not trained in that field you should probably save yourself a headache and call a professional. Always try you best to determine how bad the problem is and if it is something you can actually fix yourself.
Learning Experience:
Experience is something you can always rely on. If your first response to a blocked drain is to call in a professional you will always depend on them and will never know what problems a professional is really needed for. When you first see that something is wrong with your drain take the time to see if you can fix the problem by yourself, so if a day should come where having a professional in is not an option, you can rely on your prior experience to get the job done.
Time:
Cleaning services, for the most part, aren't available 24/7. If you a have a pesky clog that only requires minor work to clear up, you may be able to  avoid waiting days to have a professional comes by using products that you already have at your disposable such as a plunger or liquid cleaning products. This process can take a few minutes or up to a couple of hours, but it would still be more expedient then making an appointment with a cleaning service and having to wait for their earliest availability.
Convenience:
Cleaning drains can be dirty and time consuming. For people who are busy, with family or work, and don't have the time to clean their drains the option of having someone else do it is ideal. You don't have to wonder if you're doing it correctly or if you're making it worse. Determining if you've cleaned it properly or just scratching the surface. You can just sit back and be relaxed knowing that a professional is handling the job for you,
There are great advantages to cleaning your own drains at home, but as mentioned above there will be times that you must hire a professional. It really all depends on your comfort levels with drain cleaning and if your budget would allow for you to hire a professional cleaning service. Whatever your decision, you should be fully aware of all your options.
 forum activity
