Drain Maintenance Tips Drain Maintenance Tips
Drain maintenance goes a long way to keep your drains in good working condition. When practiced as a regular routine, it can help save you costs in home maintenance. Clogged drains occur all too often in the home. In many cases, the incidence of blocked drains can be minimized by regular drain care. Both kitchen and bathroom drains need to be cleaned on a regular basis. Below are 5 maintenance tips to help keep your drains in good condition.
Food Residues
These are the most common cause of drain blockages in the kitchen. It is a good practice to clear all plates and dishes of leftover food before you do the washing. This will help prevent food remnants from being forced down the drain. Use a sieve to strain food residues from pots. These can be thrown into the garbage can. You may also fit a small sieve at the drainage opening during washing to trap food residues.
Liquids
Some liquids tend to solidify when poured into the drain. This causes blockages with time. It is best to avoid pouring oily liquids into the drain. Strain off liquids that contain solid material and throw in the garbage can. It will help prevent the drain from getting blocked.
Hot Water Flushing
Kitchen drains frequently get blocked with food residues and other dirt. Scum and dirt attaches itself to bathroom drains with time. All these can effectively be washed away with hot water. It is a good idea to use hot water to flush your drains once a week. Boil a large pot of hot water. Slowly pour it down the various household drains. Repeat the action a second time. Allow cold water to flow through the drains for a minute. Hot water is excellent for clearing trapped material in the drains. It also removes grease and helps to improve the smell of the drains. It will help prevent buildup of dirt, grease and residues in the drain.
Baking Soda and Vinegar
This is an excellent treatment that will effectively clear your drains. You can do this once a month. It will also leave your drains smelling fresh. It is best to do this at night when the day’s drain usage is over. Pour half a cup of baking soda into the drain. Follow with an equal measure of vinegar. Plug in the sink or bathroom stoppers. Next morning, boil plenty of water. Remove the stoppers and flush the drains with the hot water. It will clear your drains of accumulated dirt and leave them with a fresh smell.
Sink Plunger
The plunger is a useful tool to have in the kitchen and bathroom. When you notice the water flow begin to back up, you need to use the plunger to clear the drain. Plug the stoppers over the drain. Fill the sink or bathroom with 3-4 inches of water. Then remove the stopper and replace with the plunger. A few vigorous plunges should help clear the drain of any blockage. Rinse the sink well to clear dirt.
