Login Error
Close
Drill Through A Brick Wall In 7 Steps
by DoItYourself Staff
what you'll need
  • Drill
  • Masonry bit
  • Power drill
  • Plumber putty
Drilling through a brick wall requires preparation and skill in order to prevent substantial damage to your existing wall. In order to accomplish this task, have all of your materials at hand and plan well.
Step 1 – Plan the Hole
Before you begin drilling into the masonry, you should know the size of the hole you will ultimately need. Often you will place a bolt in the hole to hold something else in place. Measure the width and length of the item. These two measurements will determine the size and length of the drill bit you need.
Generally, you should drill a hole that is slightly larger than the width of the item you place in the hole. If the hole will be extremely big, use a smaller bit initially to drill a small pilot hole.
Step 2 – Procure the Proper Drill Bit
Once you know the size and length of the masonry bit you need to use, attach it to your drill. Drilling into masonry requires a large power drill because of the density of the material you are drilling. If you do not have a larger or very powerful drill, consider renting one.
Step 3 – Mark the Wall
Mark the precise place you will drill the hole. Check to see that there are no electrical wires, plumbing or other structures behind the masonry before you start. Also, attempt to drill through the cement mortar instead of directly through the bricks. Not only is it easier to drill through mortar, but it will also prevent the bricks from shattering.
Step 4 – If Needed, Drill Pilot Hole
If you are drilling a large hole, you will first need to drill a small pilot hole. Place a smaller masonry bit on the power drill and carefully drill a small hole in the mortar where you have marked.
Step 5 – Cool the Bit
Drilling through mortar is extremely stressful on a power drill, even a high-powered one. The bit will become very hot. Keep a bucket of water close so you can occasionally cool the bit as it heats up in the drilling process. You can either pour the water over the bit or carefully dip the bit into the water. Be very careful to only get the bit wet and not the drill itself.
Step 6 – Free Bit if Stuck
As you drill, you may find occasionally that the drill bit becomes stuck in the wall. If this occurs, first try carefully reversing the bit to pull it out of the wall. If this does not work, then you will need to dig through the masonry to retrieve the bit. Unfortunately, digging through the masonry will probably result in damage to the brick, so avoid this if at all possible.
Step 7 – Seal the Hole
When you are finished and have completed drilling through the wall, thread the item through the wall and seal the opening with putty.
 forum activity
