Login Error
Close
Drinking Water Filters
by DoItYourself Staff
With the ongoing controversy over bottled and tap water, you might want to consider purchasing a drinking water filter for your family’s good health. Drinking water filter systems can be purchased for residential or industrial use.
Types of drinking water filters
Unless you are purchasing a handheld drinking water pitcher for home or dorm use, you should do some research on exactly what type of drinking water filter will suit your needs. The following are some of the available drinking water filter options.
  • Atmospheric-These work much like dehumidifiers and require no outside water source, as the water is produced from moisture in the air.
  • Catalytic Conversion-These are used in draught stricken areas and work much like a car’s catalytic converter.
  • Ceramic-These are run by a fossil-like substance that trap bacteria.
  • Magnetic-The water passes through a magnetic field and should be consumed immediately as it does not become ionized.
Tips for buying drinking water filters
Take into account that your geographic location should be considered. Some areas of the world produced better drinking water than others. There are many drinking water filter systems on the market. As with anything that your family consumes on a regular basis, you should do some research and find the healthiest option for your family.
 forum activity
