Drip Irrigation Installation Mistakes to Avoid
A drip irrigation system can help you save you water and fertilizer by allowing water to drip slowly into the root systems of your plants. Though these systems are easy to use, there are a few drip irrigation mistakes that you want to avoid.
Common Mistakes in Drip Irrigation Systems
- Number of Emitters - Always ensure that you have enough emitters to properly irrigate your garden. Avoid situations where you only use one emitter, as these devices sometimes become clogged and the plants will not receive any water at all.
- Poor Placement - Space yourr drip emitters evenly around your garden, at least 6 inches away from the base of each plant. This will help of oil avoid fungal infections and other types of diseases.
- Poor Filtration - Use the correct filter for your drip irrigation system. The wrong kind of filtration can cause major problems down the line.
- Incorrect Pressure - If you attempt to place too many emitters on a line, your pressure will not be at the minimum operating pressure that your system will need. This will cause the system to fail.
