cancel
Job type :
Zip Code :
community forums
comments
Drywall Lift: Proper Tool Use
A drywall lift is a very useful device that comes in handy when you have to install drywalls on the ceiling. Generally, the job of installing these on the ceilings is very tedious and needs 2 to 3 people to accomplish the task. However, with the use of drywall lifts this job can be done in a jiffy by just one person. There are certain things that you need to keep in mind while using this tool.
Point 1: This device can only lift one drywall sheet at a time. Do not place multiple sheets on it in an effort to save time and energy. It will not serve the purpose thus doubling your workload.
Point 2:
When using this lift to fix the drywall sheets on the ceiling, you will have to first start from the corners of the ceiling and then proceed towards the central part.
Point 3: While you are lifting the drywall panels using the lift, make sure that you balance the panels using your hands. Some people try to balance them using their head, thus risking injury to the neck muscles. This should be avoided.
Point 4: Do not lift the sheets while trying to climb a drywall lift because it will throw you off balance. It is recommended that you use the lift itself to raise the panel and take it to the desired location.
member comments
Did-it-myself Projects
updated by LessWire
did this on 4/28/2009
3 Bedroom 1 Bath Addition
updated by SKHK1
did this on 4/12/2008
Two Room Addition
How to Build a Shoe Storage Bench
sponsored articles of the day
