Login Error
Close
Drywall Removal Tools
by DoItYourself Staff
Drywall removal is not a difficult job to finish or complete. With the proper tools and a little patience, you will have it removed in no time. Remember to prepare your work area and your work surface before you begin this type of a project. Remove any furniture or items from the room and cover the remaining with drop cloths. The following are a list of tools that you will need for removing drywall.
Circle Cutter
The circle cutter has 2 sharp serrated wheels that pivot and make a sharp center tip. The circle cutter scores the surface of the drywall to you can easily knock out the plug hole.
Utility Knife
The utility knife has a very durable blade that after using the blade over and over and it becomes dull, you can just snap the blade off which then you have a sharp edge to continue the job.
EZ Rip Drywall Cutting Knife
It is very light and quite easy to use.  It not only enables you to cut you also can measure and mark with it.  It can cut different sizes of drywall. It also can cut thin pieces of drywall equally. It also has a storage area which will hold up to 10 blades at a time.
Drywall Saw
There are 2 types of drywall saws that you might need. The manual saw or the jigsaw. The jigsaw has 2 types of blades, a coarse or one that is specific for removing dry wall and helps cut in a circular or curved line. On the other hand a manual saw can do the job just as good as a jigsaw. The manual saw has course teeth, a sharp pointed end. The course teeth do feel smooth to touch.
Keyhole Saw
The keyhole saw has a long and tapered blade. They are used to cut near tight curves. Keyhole saws cut by pulling the saw and have very sharp teeth. It does make a clean cut in a hard to get area. They are usually 10 to 12 inches long. They come in either a tractable blade or a fixed blade. The fixed blade keyhole saw is not as expensive as the retractable. The retractable blade is a very sturdy blade has a handle made of cast iron. Sometimes they do have wooden handles too. If you want to save a little time rather than using the keyhole saw there are 2 power tools that are quicker and require less effort. They are the jigsaw and the spiral saw.
Drywall Rasp
This tool is for smoothing the rough edges of the drywall.
Snips
Snips are for cutting any metal that you might find when removing the drywall.
Drywall Router
This is used for making round cuts. For instance if you are removing the drywall around the light fixture box, you would use the circle cutter of the router.
Drywall Stripper
This is for the places that are narrow and very hard to cut.
T-square
This is used for used like a ruler to mark a spot and helps guide where you need to cut.
 forum activity
