Login Error
Close
Dye Stain Removal Made Easy
by DoItYourself Staff
One of the hardest tasks which you may encounter at home is dye stain removal. A dye is a chemical made to color or enhance the color of hair, fabric, and the likes. Naturally, removing an accidental dye stain is definitely complicated because some it is created to have a long term effect on the applied area. This happens normally and more commonly during hair dyeing. Since then, many tried to discover and invent some alternative solutions for this type of unexpected dilemma, but with all the stain removers available in the market today, this has made dye stain removal fuss free.
The Fabric
Simple dye stain removal starts with knowing the type of fabric that was affected. Check the back of your clothing for the tag that shows the information about the fabric, including the instructions on how it can be washed accurately. The sooner you wash the clothing, the more satisfactory result you will get on this process. Given that you already know the type of fabric you need to fix, what you can do is select the best stain remover for that particular fabric. Another important thing to be considered is the color of the fabric. It is essential to be careful when choosing the right stain remover to prevent much more damage on the fabric. If you are to perform a dye stain removal on colored fabrics, make sure that the stain remover you will use does not have bleach on it. If you are to do it on a white fabric, stain remover with bleach is what suits you best. It is vital to know all of this so you can be certain of what you can do to solve the matter at hand.
The Application
Once you have the right stain remover for your fabric, you can now apply the right amount of it on the spot where the stain is and allow the fabric to absorb the solution for about five minutes. After this process, you can now wash the fabric accordingly. You may repeat the process as many times as you want until no trace of the stain is found. Then, by utilizing a hairspray, apply a small amount of it on the stained area and again, allow the fabric to absorb the solution. Create a mixture of half vinegar and half water, then wipe it gently on the stained area once the hairspray has dried out. Bear in mind that fabrics are delicate, so you may want to execute this process as gently as possible. To make it more effective, create a mixture of half detergent and half vinegar and apply it onto the stained area. You can also use a mixture of water and a small amount of bleach to be brushed on a white fabric. Then wash it down with water, preferably cold water and wash accordingly.
 forum activity
