cancel
Job type :
Zip Code :
community forums
comments
Easily Replace Bathroom Cabinet Knobs and Shiny Things
While old bathroom cabinet knobs can really date your bathroom, the good news is that it is easy to replace them. Indeed, you’ll probably be pleased with the look of the new knobs and hinges in your bathroom.
Step 1—Choose the New Hardware
If you haven’t looked at knobs and pulls lately, you’ll be absolutely amazed and the number and variety of pieces available.
Do an online search first, just to get an idea of what you have to choose from, and then visit your local home improvement center.
Step 2 – Remove the Old Knobs
Look at the back of the drawer or cabinet door and see if you’ll need a Phillip’s head or a flat head screwdriver. Sometimes you can remove the knob by simply turning it counterclockwise, but other times you need to use a screwdriver.  Save the bolt in the back of the handle.
Step 3 – Paint Drawer or Cabinet If Necessary
If your new hardware leaves areas of the cabinet uncovered that used to be covered, make sure the surface is even and doesn’t need a bit of touchup paint before you go on.
Step 4 – Install New Hardware
Make sure the new bolt is not too short and not too long. Use the old bolt if necessary.
member comments
Did-it-myself Projects
updated by nursepammi
did this on 10/10/2009
Apt. 2 Bath Redo
updated by candbp
did this on 9/11/2009
Project House 2
updated by SMBiker
did this on 5/26/2009
Green Bathroom Demo
Painting Stylish Wall Borders
sponsored articles of the day
