Easy Pet Urine Stain Removal
If you have pets, you will need to know the process for pet urine stain removal. It is unfortunate, but it does happen, our beloved pets have accidents on our carpets. Animal urine has three specific elements:
• Urochrome; This is the sticky element
• Pigment; This is what gives it color
• Uric Acid Crystals; This is what creates the odor
The first two elements are the easiest to remove during the urine stain removal process. The third, the uric acid crystals are the hardest to remove during the urine stain removal process and can cause the odor to return on a damp or hot day.
You can purchase special products from your veterinarian to help eliminate the odors up to 650 square feet by plugging it in an electrical outlet.
Create Your Own Pet Urine Stain Removal Solution
You can use common household products for pet urine stain removal if you do not want to purchase the veterinarians products.
Pet Urine Stain Removal Solution: Step 1
• 1 part Water
• 3 Parts White Vinegar
Allow the solution to dry on the stain, use something like a book over a plastic bag to hold the solution in place.
Pet Urine Stain Removal Solution: Part 2
• 3 Part Water
• 1 Part Vinegar
Repeat process from above. When the area is completely dry, use 1 tsp of liquid dish detergent and one cup of water and thoroughly clean the area. The Vinegar smell will go away after a few days, and hopefully the pet urine stain removal process stops the pet smell from ever coming back.
