Login Error
Close
Easy to Make Chocolate Bunnies for Easter
by DoItYourself Staff
The word Easter brings to mind colorful eggs and chocolate bunnies. These treats have always been staples during this time of the year, and not having them around the table will make Easter seem lacking and incomplete. Here are some tips on easy to make chocolate bunnies for the upcoming Easter season.
Type of Chocolate
When making your chocolate bunnies, you have to determine which kind of chocolate you will be using. You would naturally choose your favorite type of chocolate. You can choose from either milk, white or dark chocolate. However, if you have the time and resources, you can do all three for variety. Nowadays, you don’t have to make your own chocolate melts and you can just easily buy them in specialty shops or craft supply stores. There are usually different bags of chocolate for sale in these shops. This makes the chocolate bunny-making process simpler.
Bunny Molds
You can also choose from a wide variety of bunny molds. These can be bought at your local grocery store or at specialty bake stores in your area. Try to determine the size and design of your bunnies. You can get bunny molds that are quite large, which are usually used for displays. There are also small molds that produce candy ideal for giving away to children.
Double Boiler Method
When melting the chocolate for the chocolate bunnies, use a double boiler method in order to avoid burning the chocolate. Do this by heating a few cups of water in a pan. When the water starts to boil, place another pan or glass bowl with the chocolate melts in it on top of the pan with the boiling water. The indirect heat will melt the chocolate thoroughly but will prevent it from burning. Mix and stir the melting chocolate until you have reached the desired consistency.
Working on Your Dough
When working on your dough, make sure that you add the right amount of ingredients to achieve the perfect consistency. It actually depends on how you want your chocolate bunnies to be. Make sure that you work on your dough well so the finished product will have the taste and texture that you desire.
Additional Flavoring
Chocolate bunnies don’t need to be made of just pure chocolate. You can add a little variety also in order to make the taste more interesting. For example, you can spice things up by adding some fresh ground peppermint leaves into the mixture so your bunny will have a little bite. You can also mix in a little peanut butter to make chocolate-peanut butter bunnies. Depending on your taste, the point is, you can mix anything into your concoction so make your Easter bunnies different and exciting.
Coating
Once the chocolate has cooled and your bunny has formed its shape, you can further coat it with different flavored chocolate. If you made dark-chocolate bunnies, dip it in white chocolate so you will have dark-chocolate bunnies coated in white chocolate. It’s like having the best of both worlds. Better yet, dip one half in white chocolate and the other half in milk chocolate. You can now enjoy all three types of chocolate in your chocolate bunnies.
 forum activity
