Easy Ways to Remove Light Fixtures
There are times when we need to remodel our homes or make changes in the offices, and sometimes it requires us to remove light fixtures to make adjustments efficient. If you intend to make removal of some light fixtures for possible renovation of the place, it can be very easy. But it also depends on the kind of light fixtures that you intend to remove. There are different types and some may not even require much effort. All you need to do is unplug and set them or relocate them on the desired spot.
Lantern Walls
If the light fixture installations are lamps that are on the walls, or externally placed in the patios, you can remove light fixtures by first removing the bulb, then the platform where the bulb is installed. It may be installed with the use of screws. All that it takes is to unscrew the installation and keep the screws and the lamp assembly where it is safe. But when doing this, the operators should make sure that the power connection of the light fixtures subject for removal is disconnected from the source. Or to make sure and avoid accidents, the main source should be shut off.
Variations of Light Fixtures with Easy Removal Procedures
After the removal of the fixture on the wall, it is important to secure the wires to prevent short circuit. The wire openings may be secured with an electrical wire and have the holes covered with a wood or preferably a colored plastic sheet that is uniform to that of the wall. To remove light fixtures, such as the solar string lights and solar accent lights, this is actually the easiest light fixtures to remove.
Moving Solar String Lights
A solar string light, for instance requires no power connection from the utility company. It is a stand-alone series of light that can be installed outdoors. The intended purpose is to illuminate the outdoors and aesthetically have it decorated. All that is necessary is to simply take them off where they are hanged and place them in a room or a compartment where it is safe. The solar accent lights are installed on poles, the lamps can be easily removed except the poles. So when you intend to remove light fixture of this type, you may want the pole to stay in its place until you figure out what is the best appearance of your outdoor.
Overhead Installations
Light fixtures that are installed overhead can also be easily removed using a ladder. It may not require additional assistance from anybody. You need to ensure that the connection from the main source is disabled. Or, it may help if the connection from the main source is temporarily deactivated by turning the switch off. In securing long wires, it will help if you have a round object similar to a spindle to roll the wires. For added safety, the bulbs in the series connection may be removed before having the light fixtures disassembled.
