Easy Ways to Remove Wood Stain
what you'll need
- Quality sandpaper (ranging from 100 to 220 grit)
- Steel wool
- Bleach
- Paint or varnish remover
- Mineral spirits
- Paint scraper
- Soft wire brush
- Old rags
- Newspapers
- Gloves
- Eye protection
- Respirator mask
There are several easy ways to remove wood stain, from light sanding to strong chemicals. The thing to remember about removing wood stain is that it should be done carefully and gently to avoid changing the shape of the wood or causing noticeable spots where the removing application was too rigorous. Removing wood can rejuvenate a new floor or piece of furniture, preserve it, or change the color completely.
Step 1: Preparation
Spread out old newspapers and tape the edges together to form a solid base on which to lay the piece of furniture. If removing wood stain from an entire floor section, mask off smaller workable areas. The idea is to apply chemicals or procedures to the parts of the wood stain that will be removed while protecting other areas.
Step 2: Wear Safety Equipment
Whether lightly sanding or applying a heavy duty chemical remover, the use of a respirator face mask is important. Eye protection and gloves are also thoughtful considerations when doing this kind of work.
Step 3: Wood Stain Removal
Depending on the task ahead, begin by lightly sanding the wood where the wood stain is to be removed. If it is a light stain, sanding lightly will usually do the job. Sand carefully so as not to change the shape of the wood or dig into it too deeply.
If the wood stain is deeper, it may be necessary to use a commercial or household bleach to help remove it. This should be applied cautiously for safety reasons and for the sake of the wood. Too much bleach will raise the grain and distort the piece.
If the stain is deeply ingrained into the wood, it will be necessary to apply a stronger commercial stain or paint remover. These products are very caustic, so be sure to follow the manufacturer’s instructions carefully. It will also be necessary to apply a heavier base of newspapers to protect other areas.
Step 4: Using Heavy Duty Paint Remover
Using a soft brush, apply paint remover generously over the entire piece, being sure to brush it into the cracks and nooks as thoroughly as possible. Allow the paint remover to penetrate the piece according to the manufacturer’s instructions. When appropriate, scrape the paint remover off the wood by gently using the paint scraper. Use the steel wool and a soft wire brush to get inside the cracks and difficult areas.
Wipe the wood with a cloth saturated in mineral spirits to remove the remaining paint remover. For more stubborn spots, carefully use the 100 grit sandpaper and gently try to rub them out. Clean the wood again with the mineral spirits and then sand the entire area with the 220 grit sandpaper. This will remove the last residue of the mineral spirits and paint remover. It will also remove tiny raised fibers, making the piece appear smooth and clean.
