Eco Friendly Building Materials for Your Home
Choosing eco-friendly building materials for the construction of your home is one important part of sustainable building. Green building materials, which refer to materials made from renewable resources, should be preferred over conventional options since the latter has less negative impact on the environment. Nonetheless, choosing these materials takes a lot more than just buying items that have the green or organic labels. You must take time and devote efforts to ensure that what you are using to build your home is truly eco-friendly. Here are some ways to do that.
Use Recycled Materials
Using recycled and recyclable materials is one of the benchmarks of sustainable building. Look for materials that have been made from recycled content. This way, you can be sure that the building materials you’re going to use for your home did not cause extra depletion of environmental resources. One good example of recycled materials are old tires, which are typically used in green building for baseboard installation, piping systems, and insulation. Metal, which is a very durable material that does not emit gases, can also be salvaged and recycled. It’s advisable to use steel, which contains approximately 60 percent recycled content. Aluminum is also a good option, but since its recycled content varies widely, you need to carefully examine documentation for recycled content.
Opt for Natural Materials
Natural materials like wood are excellent items to be used for construction of homes. Not only are these sustainable products friendly to the environment, but they are also effective and durable as construction materials. When choosing wood, you have to look for solid wood that is free from formaldehyde and solvent glues. It should also have low-emission finishes and low volatile organic compounds. It is recommended to search for locally or domestically harvested wood that is certified by the FSC. Salvaged wood is also a good option. Aside from this, you can also consider straw. Straws like wheat, barley, rice, flax, rice, or oats can be stacked on rebar or bamboo stakes to create walls with efficient insulation. Moreover, you can also take a look at agrifiber. Boards and panels made from this agricultural byproduct is typically composed of natural materials like grass stubble, sunflower hulls, corn husks, soybean plants, and sorghum stalk. These materials are also renewable and low in VOCs. Just see to it that you choose binders and sealers that are free from VOCs and formaldehyde.
Find Reclaimed Materials
These are items that are reclaimed from other local constructions. The primary benefit of using this type of material is that you can be sure that no extra manufacturing has been done to process these materials because they have already been made a long time ago. There will also be no consumption of fossil fuels nor energy wastage from the transportation of the items. Reclaimed materials can be anything from bricks, wood, timber, metal, and much more. There are many materials that you can use to build your home the green way.
