Eco-Friendly Grout Options for Granite Floor Tiles
If you are installing new granite floor tiles, or even if you are just making repairs, you may want to consider restricting yourself to eco-friendly materials. In particular, you should look at the different types of grout you can buy to protect yourself and the environment. Checking the materials used to make the grout you plan to buy before you buy it is a good start. What follows should give you some idea as to what to look for and avoid.
Zero-VOC Grout
VOC is a generic term for a variety of different substances. It stands for "volatile organic compounds" and can refer to many different chemicals that can give off toxic fumes, as well as pollute the surrounding environment. Luckily, there are many types of grout that will include none of these substances at all, and they will be labeled as such.
Epoxy Free Grout
Epoxy, while a common building material, can cause many allergic reactions for some people. Because of this, it can be best to stay on the safe side and avoid grout that contains epoxy. Again, epoxy free grout will be labeled clearly.
You should also be on the lookout for any specific materials that you know that you or your family members are allergic to.
