Login Error
Close
Eco-Friendly Ways to Clean and Maintain Granite Floor Tiles
by DoItYourself Staff
While granite floor tiles have an elegant and unique shine, the can begin to look dirty over time. If this is the case, you can take some steps to clean them in a way that won't harm the environment. Try a few of the eco-friendly cleaning methods below.
Cleaning Up Spills
To keep your granite tiles looking great, you must perform regular maintenance. As a basic step, make sure that you eliminate any spills as soon as they happen. Use a paper towel or a regular towel to immediately soak up any spilled liquid. If you allow it to soak into the granite, there is a good chance that it could leave a stain or it could leave a film on top of the tile.
Soap and Water
Another green way to clean your granite tile is to use eco-friendly dishwashing soap and water. Use a sponge to clean the floor with this method if you have a small area. You could also use a wet mop if you have a large area to cover.
Flour
If a specific area of the floor is stained, mix some flour with dishwashing liquid to create a thick paste. Apply to the stained area, put a piece of plastic over the top, and leave to sit overnight. The next morning, you should be able to scrape up the stain with the mixture, which will have absorbed it.
Steam Cleaning
One of the best ways to give your granite tile a very deep cleaning is to use a steam cleaner. To operate, simply put water in the machine, which will heat it up to extreme temperatures to produce steam. The cleaner will the force steam into the floor at high pressure. This is an ideal way to clean the grout joints between your granite tiles and remove and film or grime built up on top of the tiles. You can hire a professional steam cleaning company to handle the job for you with top grade equipment.
 forum activity
