Login Error
Close
Eco-Friendly Ways to Grow Ferns
by DoItYourself Staff
If you decide to grow ferns to add a bit of beauty to your home or garden, you should take care to do so in ways which do not cause damage to the environment. Ferns are a very popular type of plant in gardens, as they set a lush atmosphere thanks to their particular leaves. Moreover, they are fairly easy to look after, although due care is needed when their growth process begins. The following are different ways to grow ferns using an eco-friendly approach.
Grow Ferns as Houseplants
Ferns can add an exquisite natural touch to your home if you decide to grow them as potted houseplants. Naturally, you will need to use large plastic pots to house the ferns, making sure they have holes in their bottom to allow drainage. Do not overlook this requirement, as ferns do not grow in wet soil, but in moist soil. As for its place, you should find a spot which receives sunshine indirectly, such as a bathroom. You should also put your potted fern in a larger, empty pot and insulate it with sphagnum moss. If you wish, you may also place the two pots in a dish and surround them with decorative gravel. Once your potted fern is ready, you need only water it to moisten the soil from time to time, and fertilize it every month after six months from its planting.
Use a Terrarium
If you want to grow ferns indoors yet do not wish to place them in pots, a terrarium is the perfect choice. In fact, it provides ferns with their ideal humidity and moisture level, thus allowing them to grow better. Make sure the potting mix contains a mix of compost, peat moss as well as some perlite if you want to achieve the best results. As regards watering, you should only do so when the potting mix is sufficiently dry, which may not be until a whole month has passed. Also, spray a mist of water on the ferns’ fronds, since this is where these plants lose water the most. If you notice that the terrarium seems fogged up from the inside, it means that there is a high humidity level. Therefore, simply remove the lid for one day and it should clear up. Most importantly, do not place the terrarium in direct sunlight, since it would be even worse than placing a potted fern in it. Keep an eye out for pests too – spraying soapy water on the plants should deal with this problem.
Garden Ferns
    Ferns are also a great addition to any garden, although in this case you need to take into consideration the issue of sunlight. Once again, the best solution is to plant your ferns in partial shade and moist soil. Before planting, however, make sure to prepare the area well by removing unwanted grass or weeds from the planting site. Once your ferns are positioned and watered, mulch the surrounding area. This will greatly help your ferns to retain moisture.
    Growing ferns for your own pleasure should not come at the expense of the environment. These three ways will see you planting your ferns in an eco-friendly way – adding a nice touch to your home or garden while preserving the planet’s ecological milieu.
     forum activity
