Login Error
Close
Egress Window Considerations
by DoItYourself Staff
Many homeowners choose to remodel their basements to create a new bedroom or living area; however, they should consider installing an egress window to satisfy government requirements and building codes. It is a great idea to remodel unused space into a bedroom or additional living area. Basements are a great area of the home for this type of renovation. However, before you begin your renovation and remodeling project, you first need to research you local building requirements and specifications before you begin.
Building Requirements
Egress windows are simply an opening or window large enough for entrance and exit in case of fire or emergency. These types of windows are widely required by government and local building requirements and specifications in order to provide an entrance point for security personnel and an exit point for homeowners in case of an emergency. In the case of renovating your basement to add an additional bedroom, most building codes require the installation or existence of an egress window. According to most building codes, any room large enough for a bed and containing a closet or clothing area is considered a bedroom, regardless of the actual use of the room.
The average opening required for an egress window is 5 foot 7 inches. However, you should always check with your local code enforcement to ensure the required size of egress window to satisfy building codes. In addition to the size requirement of the window, there are also additional requirements relating to the well of the window. It is very important to check with your local building code requirements to ensure you are not in violation of any codes before you being your installation process.
Installation Preparation
Before you begin your installation process for an egress basement window, you need to make sure you are fully prepared for the project. After verifying and determining all building codes and requirements, you are ready to setup and prepare for the project.
The first consideration in the preparation for this project is to determine the location for the window. You will be required to cut into the foundation of your home while avoiding exterior and interior obstacles that could obstruct the installation of the window. You need to make certain the location you choose is clear from gas, water and duct lines before you being the installation. As well, you should take into consideration the desired amount of natural light you would like to receive from this window. With proper window placement, you can allow in your desired amount of light through the egress window.
Installation preparation also requires you to fully secure the foundation and surrounding walls of your home before you begin this project. Since you will be cutting into the foundation of your home, you need to make sure you have the proper retaining wall securities in place before you begin to secure your walls and floor throughout the project. It is very important that you properly secure the area around the window throughout the installation process to ensure your safety and the integrity if your home’s foundation and walls.
 forum activity
